iwanttoretireea's avatar
Apr 23, 2020
Are "all-bed" campers length safe? Most compatible all bed?
In terms of the Lance 850 and other "all bed" models like the Adventurer 89RB, how much do you trust having a 8'9" camper go into a 6 foot short bed? Does anyone have a limit? I've seen people say 8 feet camper is max for a 6 foot bed. Others say 9 feet camper.
Vice versa too, if I have to stick the camper all the way back of a long bed, there is empty pace in the middle and the back fo the truck will sag right? Isn't that bad?
Are these "all-bed" models proven to be safe? Assume we are talking about 1 ton trucks.
Also, besides length, what are some important dimensions to increase compatibility of the camper? Cab height? Wheel width? Anyone know of good dimensions to look out for to fit let's say something as old as a 2005 1 ton truck?
  • @camper8251 :) thanks for the encouragement! Im definitely excited to go on adventures in my van. I'm a young guy but Im getting too old to sleep in my SUV anymore. My biggest fear is if my car breaks down I'd like to be able to pretty much buy any used 1 ton pickup truck in whatever town I am in and be able to carry my camper. I only want to put in big money to either a camper or a car but not both.
  • Thanks, everyone has opinions and experiences. I just choose to go on the side of caution as I get older. I live in the North West lots of two lane roads and big cliffs to go off of. My biggest fear (probably unfounded) was having a blow out and losing control and taking the family and myself off the side of a cliff.. LOL. But hey I had tork lift tiedowns so the camper would have probably stayed attached to the truck in any case.
    However I dont regret owning a truck camper IMO they are the greatest thing out there. I was able to get to many places I wont be able to get to with my new TT.. If I had to do it again, I would buy a one ton dually and a nice camper but not the biggest thing I could put in the bed. Check out host campers! Dang would love one of them. But Cripes the weight of them makes me wonder how those would handle in a 3500 dually
  • @camper8251. I agree on the weight. That's why I will buy a 1 ton truck for a 3/4 ton camper.
    And I'm starting to understand about putting a short bed camper in a long bed. The COG will be off if you have to set it back past the COG potentially. I would hope the all-bed models like the Lance 350 set their COG to be good for a long bed first. And so if you do need to fit it for a short bed, the COG is already designed as forward as it can be.
    I probably would not use a trailer hitch loaded with kayaks and bikes if I use an all-bed camper on a short bed.
  • Most campers have a COG Center of Gravity Sticker on them.
    That COG should be on the axle or forward of it I believe.
    If the COG of the camper is behind the axle this will cause your front end to be lighter thus possibly losing effectiveness of the steering which would be a bad thing.
    Campers are designed for the bed they are going to fit in, I would think if you put a long bed camper in short be truck that is could cause structural issues eventually
    I am no engineer but did spend a lot of time in aircraft and there is a reason we calculate the COG.....
    Not judging but people who put campers in vehicles that are not sized correctly are asking for trouble. IE short bed camper in Long bed truck Long bed campers in Short Bed Trucks.. IMO
    Also, I think the weights are vastly understated. I had an AF 811 that was designed and supposed to work in a 3/4 Ton Truck..
    Yeah, I never really felt comfortable driving it for the 10 years I had it. I upgraded tires and suspension which helped a bit but still was always concerned. Get more truck than you need would be my advice.
    https://www.truckcampermagazine.com/newbie-articles/match-truck-truck-camper/
  • Thanks @KD4uPL for the general trends. That is very useful. For max compatibility, do you think narrow campers are worse off than wider campers because of the dually? Big wheel wells give the advantage to narrow campers right? So I guess what is more common in the pickup truck field: large wheel wells or duallys?
    So @azdryheat, yeah you need a 1 ton truck for sure. And ya those are my concerns too.
  • What I would be concerned with is that Lance says the 850 is designed for a long bed truck and it's going into a short bed. Does the short bed truck have the payload capacity for the 850? The floor length is about 9' so about 3 feet would be hanging off the bed. will that bother the structural integrity of the camper. Specs say the wet weight is 2760 pounds. Most campers have much more weight added with food, camping equipment, etc. How would the center of gravity of the camper affect handling in a 6' bed? Just some thoughts.
  • I'm not sure what an "all bed" camper is. The manufacturer will state if the camper is designed for a short bed (6.5') or a long bed (8'). A very few models are designed to fit either one. If the manufacture state a camper fits a 6.5' bed and that's what your truck has then it will fit fine as far as the bed. As you note, you likely need a 3500 series truck for most any hard side truck camper.
    My last TC was an 11' model that I carried on an 8' bed. It was actually a bit longer than 11' as many of them are. I had a 48" hitch extension to pull the boat and the ball was barely behind the camper bumper.
    Any truck will "sag" when loaded because the springs compress. Just the spring compression isn't necessarily bad. It depends on how much weight you're hauling versus how much the truck's tires, springs, axles, etc. can handle.
    As for fit, Ford cabs are often too high for older campers and the camper needs to be lifted on foam insulation or plywood to clear the cab. In 2007.5 GM narrowed their tailgate openings a little so older campers are tricky to load because of that. If you have a small, narrow camper that is only 7' wide and want to put it on a dually it will be difficult, even with dually brackets, to get the jacks far enough apart.
  • I would never recommend a mismatched TC....length, weight etc.
