Avid_Fox
Apr 21, 2021Explorer
otrfun wrote:Avid Fox wrote:We just built a 200ah LifePo4 battery pack that fits inside a group 24 battery box for approx. $750 purchasing cells and BMS from US distributors (~$550 purchasing from China). I've easily gotten ~160ah out of this battery pack under high loads (>100a) discharging from 100 to ~20% SOC.
I can carry two group 29s in my AF1150.
Are they worth it?
You could easily fit two of these in your truck camper. This could provide you with 320-360ah of unrestricted, usable power without stressing the battery. LifePo4's can be discharged down to almost 10% SOC under extremely high loads with only a .2v to .3v voltage drop (lead cells drop 2-3 times as much). With proper cabling you'll have zero worries about low voltage inverter alarms.
With 320-360ah you could power a typical 10k-11k truck camper a/c (120vac, 10-11a) for at least 3 hours (100 to 20% SOC) with the compressor running 100%. With the compressor cycling you could probably get 4-5 hours. Amazing performance from just two, small group 24 sized LifePo4 DIY battery packs!
And what do you use for charging them? Are they in a truck or RV which use DC charging sources?
