otrfun
Apr 26, 2021Explorer II
time2roll wrote:According to BattleBorn you can safely charge LifePo4 cells below 32f (0c), but you must reduce the charge current accordingly. I would prefer the option to reduce/limit charge current when temps get down to say, -3 or -5c, rather than rule out all charging below 32f (0c). That's one of the reasons I'm hoping to find a LifePo4 charge current/rate vs. temperature chart. Of course, to pull this off you need a programmable BMS. A nice advantage of a DIY LifePo4 cell pack.
Generally the BMS will halt charging at about 0c and halt discharge about -10c.
Of course no reason to get below 5c as you would want to add a heater if going that cold. However your battery would be protected if an unexpected cold snap was to slam down suddenly.
44,071 PostsLatest Activity: Aug 23, 2026
