A390GTExplorerSep 23, 2015Are slides safe to use in the closed position?We are looking for a double bunk travel trailer with a dinette and sofa in the slide. We would like to be able to use it closed while stopped. We have two boys that will be jumping on everything a...Show More
TequilaExplorerSep 23, 2015Good question, when its in the outer edge of the slide is up against the outside wall which should be providing some support.
Related ContentAdding power outlets in slide with no wiringCorrect position of Topper for Slides when closed.Slide out position at homearctic fox slide adjustmentSlides won't close
