Huntindog
Sep 23, 2015Explorer
A390GT wrote:If you are dead set on doing this. I would at a minimum support it at the corners, and then every 16" just as most floor joists are spaced.
Ok so it would need to be supported in 3 places on the front inside open side. Both of the corners to stop the tilt and one dead center to stop the sag..
One in the middle IMO is not enough... In my case my big slide would have a 7' span unsupported. That WILL flex a lot.
But this is just not a good idea. Shimming will run the risk of damaging the tile. under the shims
