JiminDenver
Nov 20, 2014Explorer II
MargaretB wrote:old guy wrote:
yes all have their different problems, I had them with one TT I bought and at one time I worked at a RV dealership and the one thing I can tell you is stay away from entry level TT's. they are cheaply built. now, all TT manufacturing is not rocket science but the better or higher priced models are your best bet. better quality materials go into them.
I'm not sure what qualifies as an "entry level" TT. Weight? Length? Price? Features?
I was thinking of situations analogous to the Yugo - universally regarded as being of poor quality.
I don't think all entry levels are built the same. I've heard more than once that the simpler they are, the easier they are to build and the less to go wrong. Some you can see where the cost and weight reduction is, others you can't. it's the hidden things that will get ya.
In our light weight, entry level, 3 season trailer you can see the plastic sinks and toilet, the OSB in the cabinets, even the fact that it is narrower and shorter than a regular 25 ft trailer. Luckily it has a solid wood floor, not foam core and they didn't cheap out on the frame, it has a CCC of 3000 lbs. The construction is much the same as other GS rigs except it can fit places the bigger ones can't. It has also been fault free for 4 seasons even though we drag it over the rough back roads of the Rockies and see all the extremes in weather.
As far as fit and finish goes, from what I have seen more expensive means nicer stuff but not necessarily better fit and finish.
