Saturated_FatsExplorerSep 12, 2014Are these CAT scale results possible?Got my F-150 and 5th wheel weighed today and the CAT scale came up with the following: Steer axle: 7540 lbs Drive axle: 940 lbs Trailer axle: 7480 lbs Gross weight: 15960 lbs I haven't done t...Show More
azwildcat99ExplorerSep 12, 2014You probably pulled too far forward and had the drive axle mostly on the steer axle weight pad.
Related ContentFirst mileage test result.First tow resultsBlowout Resultsmicroair easy start resultsPossible???
