wgriswold's avatar
wgriswold
Are trailer brakes adjustable?
In August I had the wheel bearings packed and afterward, on the way to storage, I noticed that the brakes were not nearly as effective as they before. Even with the controller turned all the way up they weren't right. My first thoughts are either grease on the shoes or they are out of adjustment.
The guy at the shop that did the packing just told me that trailer brakes are not adjustable. Is that right? The trailer is 75 miles away and I will not use it until January and then I will take it to a shop to investigate this problem. I want to be knowledgeable when the time comes.
Thanks.
  • You went to a guy and you should have gone to a mechanic. The brakes are adjustable.
  • trailer brakes are adjustable with a few exceptions. If you have disc brakes on the trailer they are not adjustable. Some of the newer trailers have self adjusting brakes.
    I think I would find a new shop
