egarant's avatar
egarant
Nomad
Aug 03, 2022
Armless Rear Awning
Hi,
We are all familiar with the standard rear awning that you get on a rear entry truck camper, they have the arms on the sides that if you don’t extend the awning all the way out you have a chance of hitting your head on the unfolded awning arm.
I would love to put on of those newer armless awnings in place of what I have. I would even be open to a hand crank version.
Has anyone seen or done something like this?
Thanks,
Mr E
  • MORSNOW's avatar
    MORSNOW
    Navigator III
    Carefree box awnings. I have on the dining room side of my camper.
  • I’m also interested in options for a rear awning that doesn’t have arms on the sides, great topic. Does anyone have photos of DIY solutions that work?
    One thing that I saw on a trailer recently that might work on a truck camper was the use of a molded plastic Velcro-like strip that was attached across the top area above the door frame and a pair of eye-straps or other physical anchor points at each end. Then a pair of typical awning poles with guy-lines at the outer ends of the awning.
    Thanks for any ideas on this!
  • They're called Box Awnings, Carefree from Colorado makes multiple models, both electric and manual crank.
    The only hiccup you might run into is the amount of space between the top of the door and any overhang for the tail clearance lights you have.
