MADDUO's avatar
MADDUO
Artic Fox 811S
Hey everyone! Looking for some help. I have an AF811S and am curious about the strength of the rear aluminum bumper. I need to carry a 2nd spare and am curious if the bumper would support a Tiregate Adventure series Universal Hitchgate plus a spare. Weight would be approx. 190 lbs.
If anyone can help I know the great people of this forum can. Posting pics of other people's solutions would be great too. I have looked into a front bumper mounted solution but I need to reserve my front receiver hitch for my mtn bikes.
Thank everyone and look forward to your solutions.
Doug.
  • It's a 2010 if my memory serves me correctly. I agree it is alot of weight. The tire carrier is 101 lbs, so maybe I could find a lighter solution and just have the weight of the tire. I'm guessing rim and tire are around 90. Im sure I've searched about putting it on the roof, but can't remember what was said about that. The big problems I see with the tire on the roof is mounting it and retrieving it. Plus the weight of it on the roof can't help with the already top heavy characteristics of the camper itself. Im pouring over google now trying to find solutions.
  • Northwoods second generation bumper would probably work. Its much beefier and mounted much stronger for the Fox Landing step. If you have the earlier version like many do, Im not sure I would want to add that much constant weight to it. Keep in mind that a 200 lb person using the bumper along with the spare tire and carrier could put almost 400 lbs on the bumper.
  • If I was you I sure wouldn't put that type of weight bouncing up and down as you go the road on the rear bumper. I believe that they are just screwed into the back of the camper which is fine for entrance and exit of the camper but not meant to support weight in motion. I would find or make up a swing out mount that could be used in your rear receiver. Or switch where you bikes ride and put them on the rear and then use a front tire mount for the front end.
