rexlion
Mar 29, 2014Explorer
Assume diesel and gasser have same torque, compare...
Let's say you could get a particular vehicle with either a gas or a turbodiesel engine. And assume that both engines were rated about the same for torque, but the gasser would have 50% higher max HP. If you wanted to tow a moderate size TT up a 5%-6% grade (assume low altitude for this hypothetical), would both do about the same at maintaining highway speed? Would you expect the gasser to do just as well as the diesel at this task, other than the need to rev maybe 1000 rpm higher than the diesel?
