Gdetrailer
Jun 25, 2014Explorer III
Broccolli wrote:Gdetrailer wrote:Broccolli wrote:
Hi all! I have a 25 foot 93 Dutchman Royal that has some pre existing water damage in the rear bedroom. My child is afraid to sleep in there as it just looks scary.
I was wondering (as a single mom) has anyone used a contractor to rip walls out of one room and re-post with hopefully 2x4's and panel (with a thicker wall) we have permanent site and want strength to the support.
We may add twin bunk-beds (so I can sleep in the same room and calm my baby's fear) but as of right now are unable to throw tons of cash into it.
If you have gutted one room via handyman/contractor what did it run you cash wise and how long did it take?
May add bunk beds one at six inches off floor (so I can clean under and one 42 inches above it so we still have cabinet access and neither of us crack our skulls open.
Thanks in advance and please feel free to not have a filter! Iam looking for all opinions <3
I wish it was easy and cheap to do but it isn't.
Most likely if you pull the paneling off you WILL find much more extensive damage.
Finding a contractor who is even willing to tackle this job is going to be like pushing a boulder uphill with your nose. Not to mention the hrs of labor cost that will be involved.
I would suggest you take a look at my rebuild.. Granted it was the entire trailer, front to back inside and out and nearly took me almost 3 yrs to complete and the better part of $5K-$6K in materials alone..
KOMFORT REBUILD LINK
A note about the above link.. Google for some reason insists on using their own PDF viewer which makes a mess of the pictures. If you want to veiw the pictures properly you can download (save as) the PDF and open it with your local Adobe Reader. File is large and may take a a little time to download.
Thank you Gdetrailer, did your contractor work with you and allow you to pay as you go to redo the entire camper (great idea by the way)
Broccolie,
I should have made it a bit clearer, I did ALL the work myself. There was NO "contractor" involved. I spent nearly every free minute I had for nearly three years. 2hr-4hrs every week night and often 10hr-12hrs each Sat and Sunday..
RV construction does not make it easy to tear apart, refurb or flat out work on. You often can not use normal carpenter tools in normal ways since you are often working in very tight spaces. RV construction does not use 2x4s, instead they use 1x2s and the interior paneling is GLUED AND STAPLED to the studs. Extremely time consuming to remove and causes a lot of damage to cabinets and other walls. Just the way it is..
If I was to hazard a guess on labor cost for my rebuild I would guess you could take the material cost and at least DOUBLE it and then add 25% more to that for good measure.
Rehabing your trailer just in the one room alone most likely will set you back $2K-$3K in labor and materials and that is if no other major damage needs fixed.
As far as finding contractors that will wait to the end for payment, good luck. Many are going to want a deposit to cover at least materials IF you can find one that is willing to take on a RV.
Your best bet is to find someone who is a "handyman" carpenter and even then you might have a tough time convincing them to do it.
I wish you luck but this is more of a DIY thing with RVs, there is no money in them for folks trying to repair and rebuild them and in the end the value is determined by the year of manufacture.
44,056 PostsLatest Activity: Jan 12, 2020
