Huntindog
Jan 14, 2020Explorer
goducks10 wrote:
The HA/PP are semi permanently fixed to the tongue so it's part of the TW. Same as adding a couple more batteries.
I disagree. When any style of hitch is hooked up, they are semi permanently attached to the TT.... But none of that weight should be used to calculate TW.... TW percentage is a figure used to determine the INHERENT stability of the TT alone....If you cheat on this figure, you only cheat yourself.
