goducks10
Jan 14, 2020Explorer
Huntindog wrote:goducks10 wrote:
The HA/PP are semi permanently fixed to the tongue so it's part of the TW. Same as adding a couple more batteries.
I disagree. When any style of hitch is hooked up, they are semi permanently attached to the TT.... But none of that weight should be used to calculate TW.... TW percentage is a figure used to determine the INHERENT stability of the TT alone....If you cheat on this figure, you only cheat yourself.
The main body of the HA is left bolted to the tongue when done towing. Same as the propane tanks, batteries or the chain pull ups.
Unlike a standard WDH where the main body is slipped into the receiver the HA is attached to the tongue.
