silverfoxn
May 28, 2015Explorer
The break-a-way is hot wired and the smoke detector and the propane detector is not hard wired to the battery. Still trying to fine out what is staying on. I did find a shut off valve in the water supply line from the pump to the tank. Guess that is there so that the pump doesn't loose it's prime. Should work if you like standing on your head to shut it off. I'm saving the other problems for later. Keep watching!!!
