BulldawgFan wrote:
Your mechanic doesn't know what he's talking about regarding the brakes. F250 SRW and F350 SRW have the same brakes. If you have the camper package on your truck, you have the extra overload spring the 350 has plus you get the rear sway bar.
S
He is not the first I had heard that from. If those aren't the differences, what are?
Also, as I purchased the truck used, how would I know if I have the camper package, with extra spring and sway? (I do have the factory 7way and the factory brake control.)
The auxiliary spring is the shorter spring on top of the standard spring pack. If you have that and the rear sway bar then you have the camper package.
Here is a picture.Another slight difference with the F350 ('11+) is it has a 4" block between the spring pack and axle. The 250 has a 2". All it does is raise the rear of the truck 2 extra inches so when you load the box up it sits more level and less likely to engage the auxiliary spring.
