alenk
Mar 12, 2015Explorer
Well, I tried. I took the door off, disconnected the reset switch, and took the 7prong plug off the board. Then I took the fan housing off, and the Sail Switch was mounted on the underside of the housing. I blew all the dust out of it with my compressor. Blew the dust out of the squirrel cage and exhaust area. Then I plugged all the electrical back in, and turned it on. Then I let the blower blow about 30 seconds, and then I held the sail switch on, and the gas igniter worked, and the burner came on! So it worked while I held the sail switch on. Then I put everything back together, and it didn't come on after all that.
Therefore, I have decided that the Sail Switch isn't working without help, so I'll order that switch and put it on. Then maybe it'll work as it is supposed to. Anyway, I feel better about things than I did yesterday.
Thanks, everyone! This is an awesome forum!!
Al
Al
