RDWhipp
Dec 10, 2014Explorer
Atwood Furnace problem
New Atwood Excalibur 8531-1V
New Atwood Hydroflame 2000 thermostat
New Camco Double-Stage Auto-Changeover Regulator
2 7 gallon bottles, full.
No leaks or kinks.
13.6 V from converter to unit. Polarity correct.
70” return air.
Blower runs fine.
Thermo set at 68.
Unit cycles on at 65, blower on, clicks and no flame 3 times. Shuts down and thermo points remain closed. Board lite indicates lockout.
Rests for approx. 10-30 min. more or less, then cycles on, fires up on first, second or third try most of the time, points open at 68, flame off and blower purges normally.
Comes on at 65, shuts down, then begins irratic cycle, fires up 2nd or third try, sometimes flame and lockout.
Unit then repeats the no fire cycle.
No regular pattern.
Took it to an Atwood Service center and they said they couldn't get it to fail with their bench test. Would a board test make sense?
Any advice would be appreciated. Atwood does not respond to my email.
No leaks or kinks.
70” return air.
Blower runs fine.
Thermo set at 68.
No regular pattern.
