dave86357ExplorerMay 10, 2019Atwood hot water heaterMy atwood hot water heater isn't burning hot enough with the flame.It lights everytime I turn it on. I see soot rising from the chimney. No issue with the propane. Any help would be appreciated
cavieExplorerMay 10, 2019Needs cleaning. Remove the outside cover and clean inside the burner tube. Spiders love the smell of propane. You should not be seeing soot.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Atwood hot water heater
