mfoster711's avatar
mfoster711
Explorer II
Jul 19, 2014
Atwood Power Jack installation help
I bought an Atwood power jack and need to install it. I am a little confused because the jack has only one wire coming from it. The wire is black but has a fuse. I believe this is the main power wire that needs to be hooked directly to the positive side of the battery.
So, where is the ground wire?? I thought there would be another wire for grounding but there is not.
  • Boband4 wrote:
    It makes the ground through the frame connection. Usually recommend using the star washers to ensure a good metal to metal contact. You are right, the one fused wire goes to the positive post on the battery.
    X2
    The star washers should cut through the paint, but it doesn't hurt to to take scratch up the frame so to make sure that you get a good ground.
  • It makes the ground through the frame connection. Usually recommend using the star washers to ensure a good metal to metal contact. You are right, the one fused wire goes to the positive post on the battery.
