Traver8
Aug 19, 2019Explorer
Atwood Water Heater Relay - Stuck Closed Again
Hi All,
I am back again with a recurring problem that I am struggling to understand. Yesterday, for the third time in 6 years I had the relay for the electric side of my Atwood water heater stick closed. Fortunately, I was here and recognized the issue of very hot water pouring out of the temp/pressure relief valve and opened the breaker to shut it off.
I have not yet given anything a detailed look but have confirmed that with the 12VDC control switch OFF, I can close the breaker and hear the element start heating.
I have already ordered a new relay and will dig in again tonight and see what I can find.
Anyone out there have any theories as to what might be causing this? The last time was in Nov 2017 and my theory at that time was a poor connection on the 120VAC side had caused some local heating which caused the contacts to stick. I corrected the connection and replaced the relay at that time and all has been good until yesterday.
Details are:
2013 Jayco Jayflight
Atwood Gas/Electric water heater.
Stock Progressive Convertor
Dual 6V AGM batteries
Measured convertor output - 13.2VDC, AC ripple 2 mV
What else?
Thanks for your help.
Terry
See here for the Nov event discussion.
https://forums.trailerlife.com/index.cfm/fuseaction/thread/tid/29480209.cfm
Details are:
What else?
Terry
