moonlitsouls
Apr 04, 2021Explorer
Buzzcut1 wrote:moonlitsouls wrote:midnightsadie wrote:
normal spring start up.# one light the stove, that will get air out of system. make sure the heater is full of water. try lighting ,some times on first light up of the year might take couple try,s listen for the click.
sorry what will get the air out? i didnt understand
You need to run the stove burners and the furnace to clear air out of the propane lines. Even then its going to take a bunch of tries to light the water heater as that line still needs to be purged of air.
Click here
i posted a photo of the unit i have here, i got it from youtube but mine looks the same, if i remember correctly , the troubleshoot instructions say to open the valve first , i was trying to work on this from below as the camper was 10 feet in the air, ill have time to remove it from the truck and lower it to whhere i can actually see whats going on and ill report back. to open the valve , i need to use an allen key yes?
