Mikesr's avatar
Mikesr
Atwood WH Drain Plug
Anyone know for sure what size socket fits the Atwood drain plug ? New to Atwood have always had Suburban before with the anode rod.
Atwood plug is plastic, does it need replaced often ? Does it need Teflon tape? Are the replacement plugs that have drains built in worth it or is it just as easy to remove the plastic plug?
Thanks
  • My Atwood is 7/8"
    Don't use any Teflon tape.
    Mine now is six years old and I have never had a problem with it.
    Just snug it up and don't over tighten it.
    Jack L
  • 15/16 six point is the best.
    Using a six point socket saves the corners so the plug lasts longer.
  • Atwood used 2 different size plugs (drain hole is 1/2")
    One plug used a 7/8" socket and other plug uses 15/16" socket
    Plugs are nylon tapered thread so teflon tape is not needed but can be used
    Plug threads do become damaged but come 2 to pak when purchased. Nylon is used due to WH tank being aluminum. Nylon is also used due to it's temp rating
    And with the drain hole size it is hard enough getting crud flushed out when draining/rinsing tank. Screw a plug in with built in drain you just make drain hole size even smaller.
    I turn off water supply, pressure on HOT water system, remove drain plug and then turn water supply back on and let it blast out thru drain hole. This helps remove crud from bottom of water heater.
