jepalmer's avatar
jepalmer
automatic transmission flush
I'm due the 90,000 service on my 2011 F350 diesel. The dealer is recommending a transmission flush. Is this worth it, or are they just trying to make a boat payment?
  • Is it really some kind of power flush or is it just a full fluid exchange?
    I would tend to drain and fill the pan and then do the exchange to get new fluid in the torque converter. Replacing the filter is over rated. More of a strainer. The media just does not get dirty like an engine oil filter.
    So glad I have a torque converter with a drain plug.
  • Depends...
    I used to say flush all the time, but that is based on my personal
    routine of flushing all my automatics on a regular schedule of 20K or
    two years, whichever came frist
    Well, bought a used 2000 Honda Odyssey. IIRC, around 130K miles when it
    started to shift 'funny'. Previous were Christian Missionaries who
    moved to China. Found pet hair, candy, spilled soda, etc where they
    missed with the steam cleaner...it must have been the 'bus' for church
    trips...
    Flushed it and the tranny shifted better for a few hundred miles...then
    it barfed and wouldn't shift right at all.
    Had it rebuilt and is good for a long time, or hope it will be...
    IF the OP's automatic hasn't been flushed before. It has been used
    HARD towing heavy...then just a pan drop and no complete flush.
    What happens is that the ATF in doing it's job, burns at the tips
    of the TC vanes. That is the 'slip' of any automatic and why all
    now have a lock up to prevent that 'slip'
    That 'slip' is where the AFT shears and that is also where the torque
    multiplication comes from
    IN shearing, it can get hot enough to burn the ATF and cause it to
    oxide and form varnishes that will then coat various surfaces
    As the valve body parts wear...that varnish coats to mask that wear
    and tear
    Flushing the whole charge will introduce new ATF with all of the solvents
    built in. A pan drop and change will only change a percentage (small)
    of the whole charge. So the solvents are diluted
    Solvents will remove some/most of the varnish to then have the moving
    parts either loosey-goosey or clog a moving part
    The OP's at 90K miles. So up there and if towing hard/heavy, then
    there is a danger that the OP's tranny is varnished enough to cause
    a problem if a whole flush is done
    Most of the ATF is in the TC. A small portion is in the tranny pan
    of 'most' automatics.
  • gkainz wrote:
    transmission experts I know say "DO NOT FLUSH!" ... drain the pan, change the filter. If you want the TC fluid changed, remove the output line to the trans cooler and idle the engine. As the old fluid pumps out, add the same amount into the fill port. Once you have clean fluid pumping out, stop, shut down, reconnect, restart, check and set proper fluid levels.
    Just had our Toad done that way.
  • Money generator, nothing wrong with old way. No reason to flush all the wear debris around in the spool valves, and pray in shifts correctly after.
  • That is the mileage for a transmission fluid recommended by the Ford manual for normal maintenance.
    I have previous trucks and Expy done at recommended mileage with no subsequent problems.
    Edit: Oops! 90 k was the previous truck. 2012 says 150,000 miles for transmission fluid change.
  • RAS43's avatar
    RAS43
    Explorer III
    Boat payment IMO. Ford recommends a drain and fill with external filter change, not flushing. Dropping the pan may be good but again, not recommended. And since there is a thermostat inside that controls flow to the cooler, the oil in any flush machine must be heated to open the thermostat so ask if that is done if you decide to go with their flush. And if they use chemicals to flush-run away! They cause more harm then good.
  • transmission experts I know say "DO NOT FLUSH!" ... drain the pan, change the filter. If you want the TC fluid changed, remove the output line to the trans cooler and idle the engine. As the old fluid pumps out, add the same amount into the fill port. Once you have clean fluid pumping out, stop, shut down, reconnect, restart, check and set proper fluid levels.
  • I prefer to have the pan removed and checked for debris. My transmission place also blows old fluid out of cooler so as to remove old fluid.
    Only bad thing is the converter doesn't always drain leaving some old fluid there.
    Transmission flushes do not replace the filter if equipped.
