Bionic_Man
Sep 23, 2017Explorer
tinner12002 wrote:
With all that being said, those that have the tanks, how do you control the flow, do you stop and open a valve then watch gauge then stop and close the valve or is it in the open position all the time??
I have thought about putting a RDS tank in but had also thought I use a normally closed 12v solenoid valve that I could switch open while driving then switch it off when its filled or nearly filled the truck tank...any ideas??
My valve stays open all the time. As long as both fuel caps are on tight, the tank will not overfill.
