transamz9
Sep 26, 2017Explorer
mkirsch wrote:
Curious, how does a gravity feed setup work? Seems to me that it would just keep gravity feeding until the top tank had run all the fuel on the ground!
Like I said in my previous post, there is a tee installed into the factory filler tube down next to where it goes into the factory fuel tank. That tee is where the line coming from the aux tank is hooked to feed the factory tank. Inside of that tee is a check valve that shuts off the fuel coming from the aux tank when it gets to that level. As the truck burns fuel the check valve will allow fuel to flow in until it fills back to that point. My particular set up gravity flows through a 3/8" line to feed the factory tank. It keeps my factory tank full until the aux tank runs out.
