enblethen
Oct 09, 2013Nomad
Second battery location is normally for diesels.
To use as an auxilary battery, you would need to isolate it. I donot care for diode based isolators. A more robust is using a relay such as these and wired per instructions. The coil of the relay would be wired to a location that is "hot" when the ignition switch is in the "run" position. Remember to install some type of fusing to protect the system.
Battery disconnect
Battery disconnect
