Peg_Leg
Oct 09, 2013Explorer
I've ordered my last 4 trucks with the auxiliary battery option. On my present one the battery cable runs from the power distribution block on the passenger side across the top of the firewall to a battery isolator and then on to the auxiliary battery.
The battery isolator isn't like the one pictured above. It looks like the starter solenoid for most riding lawn mowers. You need to make sure it's rated for constant duty and high amperage. The solenoid will have two large terminals across from each other and two small terminals for the energizing coil. The coil should be wired so it's only activated when the ignition is on.
