Dayle1
Aug 21, 2014Explorer II
Nothing wrong with gravity feed with a diesel engine, you just need the right hardware to prevent fuel spillage. I think Northern Tool sells the kit. OTOH, if you are going to spend the big bucks that would be needed for an electric pump, better to spend the same amount of money on a larger replacement tank instead. You don't loose bed space and you only use the normal fuel filler.
44,071 PostsLatest Activity: Aug 16, 2026
