enblethen wrote:
Monkey44: you may want to check and get your lights adjusted.
OP: I installed a pair of LED driving lights wire through a switch in the control circuit to a relay to act as daylight running lights. The switch is to turn them off when parking so as to not blind other campers. relay is wired to a good 12 volt hot location and the control is wired from a hot in run fuse location.
I aimed the lights slightly to the right so as to not blind on coming traffic. They are mounted lower then center line of headlights.
My lights are fine - it's the oncoming drivers that hit eyes high and bright. Manufacturers continue to brighten lights for safety, but eventually will brighten themselves right out of safe driving at night.
