hornet28
Mar 25, 2022Explorer
thomas201 wrote:
When I had diesel, I used gravity feed. With gas, I have to pump. I would not pump diesel, because if you leave the pump on it will have to go somewhere after the truck tank is full. So, if you pump, you need a return line to the deck tank. Just saying.
Diesel or gas you overfill the tank it's going somewhere. A return line isn't needed. The trick is to have a reminder such as a buzzer or light in the cab to remind you the pump is on. If one of those doesn't do the trick well, "You Can't Fix Stupid"
