kohldad
Jan 13, 2022Explorer III
I am not familiar with Lance campers, but it will need to be determined if the specific model in question is build (from the factor) such that is can be used on a short bed truck. i.e., the overhanging portion can be self supporting.
Yes, the Lance 815 is designed for both long and short bed trucks. The camper is wired to accept two pods at the rear corners. The pods are plugged into a standard 4 prong connector and provides the taillights when used in a short bed truck.
thanks for the picture, the only difference is you have the hangover in the back so that say someone slammed into you, the hangover would hit up against the truck bumper and the camper wouldnt not slide forward. In my case, the the Lance 815 has no hangover so it potentially could slide forward and squish my aux fuel tank up there? I guess that wouldnt be a big deal, perhaps the tank would work as a buffer?
Odds are the camper is going to crumble before the fuel tank does. If this is a big worry, it would be real easy to fabricate a heavy duty cage to protect the fuel tank. As long as the tank sits up about 2" so the camper floor would slide under the tank, there isn't anything else in the area to provide much force.
Nobody gives a second thought to the main fuel tank getting "squished." Why worry about this one?
Main fuel tank for any modern truck to my knowledge has the main fuel tank between the frame rails. Even chassis trucks with the tank in the rear are mounted between the frame rails and usually protected by the the rear bumper integrated into the bed or box attached to the truck.
