pressure_welder
Jan 24, 2016Explorer
Auxiliary in bed fuel tank question
Good afternoon everyone, hope all is well ! I have just finished installing a custom made tool box/auxiliary tank combo that I made up in my new 2015 ram cummins 3500 limited dually ( came from a 2015 duramax . With my particular setup I have an extra 60 gallons on board which will be awesome come towing season. The plumbing is setup like this.... 3/4" ball valve from the top of the suction tube, to a 10GPM 3/4" fuel pump, to a fuel/water separator, and then piped directly to a welded fitting on my stock filler neck. All of this is controlled via a "keyon" only switch.
Now my question is this... I was just curious whom of you have a similar setup to this? I know I am moving a fair amount of fuel with my pump, and I thought I would have adequate venting on the stock fuel tank on the truck however as you cummins guys know we have the capless filler neck with two flappers, and the vent location is just past the second flapper. It seems both flappers have to be depressed to create venting on the truck tank. I know there is a "high point" vent on the filler neck although I am not sure how much that does. Anyway I tested out the system and ran it for maybe 30 seconds which brought me from 3/4's of a tank to full. Just for curiosity i depressed both flappers in the filler neck with a screw driver and got a somewhat decent puff of air so I know I am building some pressure via the transfer pump. I am just curious to see what some of you may have done to remedy this issue? at this point I see myself taking off the filler neck assembly again, welding a bung on the vent tube and running another hose into the box with filter on it to provide venting. Am I missing something as far as the stock fuel tank venting adequately while both fuel flappers are closed? I would think there has to be a way for this thing to vent with both flappers closed? however I didn't hear anything hissing after I turned the transfer pump off.
take care!
take care!
