Bionic_Man's avatar
Bionic_Man
Question for those with an Auxiliary diesel fuel tank
So, for the 2nd time in 3 years, my in tank fuel pump on my RAM failed. Happened two weeks ago pulling my boat on a 500 mile trip to vacation. The good was it didn't leave us stranded, happened in probably the best possible place, and was able to limp into literally the last town with any mechanics for about 250 miles.
Dealer said that the fuel pumps are very reliable, and they don't know what is causing the problems.
On the way home, I ran the 60 gallon RDS tank dry, and looked into it before filling it today. There is definitely contamination in the tank. I am wondering if this is normal (since I can't see into my OEM tank, I really have no idea what is in there), or if this could be the root problem of my fuel pumps taking a dump?
The tank is plumbed into the filler tube, drops into the main fuel tank. I am wondering if I should put in some sort of fuel filter to go between the aux tank and the OEM fuel tank? If so, which would be the best way to do it?
FWIW, I almost always fill at the same station (which I will now change), and am good about changing my fuel filter every other oil change.
Thoughts?
