gazelleTT
Jan 18, 2015Explorer
Awning help on 2008 Palomino Gazelle G210
Hello, I have a 2008 Palomino Gazelle G210 with 15' awning.
I replaced the Awning fabric yesterday following a youtube video for guidance but have a few questions.
Question 1: I have an A&E awning, but no idea what model, the sticker is unreadable.
How do I tell? It is stock to the trailer, manual operated.
Now question 2: When I replaced the fabric, I unrolled the tension on the right hand side counting my turns as I undid it. It was 7. I removed right hand end cap and removed spring on right side. The spring on left side had no tension whatsoever. I never had to do anything to left side. Is that normal?
Installed new fabric and wound up spring 7 turns, installed awning to trailer and realized I had wound the spring the wrong way.....(duh..) So while still attached to trailer, I released the awning, letting it unroll slowly until it stopped. I Removed right hand of roller from support arm. Placed lever position in roll down position and using vicegrips on bracket, wound it CCW 7 turns. Put it back together and everything worked correctly except it didn't go back in all the way to trailer. About 2-3 feet short. SO I removed roller again from right arm and gave it about 4 more CCW turns until it rolled up tight to trailer.
My question here is, how tight should it pull up to trailer?
Any advice on all 3 questions would be greatly appreciated. Thanks!
