ffbillyny wrote:
I purchased and installed these China lights last summer. I spliced into the 12v from my porch light. I used the existing housing from the porch light to hold the receiver and sealed it with silicon. Finished the install and first try the lights went on...I was impressed. The only problem is the remote control did nothing. I emailed the company and have since received 2 additional remote controls and receiver boxes, none of which have worked. Does anyone have anything thought? Anything I can try? They do work with one color, so it is not a totally lost cause. I would just like to be able to use all of the colors.
One set I received had no connection from 2 of the 3 wires to the strip. Was able to solder them on but since fell off the TT.
GENTLY pull back the connection sleeve from the wire to the strip. You'll see the connection point. See if they are all connected
