My daughter has a K-Z Escape trailer and recently they came back from a week-end camping and the rear lower mounting bracket that holds the awning assy. against the trailer came out. There are two sc...
You should also state the construction method as in stick & tin or fiberglass siding. The Escape may all be fiberglass and there is no framing to speak of, just aluminum tubing at corners and major openings. KZ uses thin sheet metal under the outside layer of the siding on fiberglass models for awning attachment.
