NJ6PACK's avatar
NJ6PACK
Awning Problem
Hello, I havent posted in a while, just reading posts and now I jave a problem.
I was getting the TT ready for the season and when I went to extend the awning it would stop after I extended it about 90%, seemed like it was binding up, thinking that it might need to be lubed or gunk might be in there (I admit I not 100% on awning knoledge) I pulled real hard and got it out all the way when I did that I heard a lound "Clank" inside the tube
Once out I can hear something rolling around the tube about 4 feet from the end and now when I go to roll it in the tension for rolling it in is about half of what it was, when I move the lever to roll the awning in it does go in and it does seem to lock just not the same tension as before
Is the spring broken?
I have a weekend trip planned for next week, less than 20 miles that does include driving on the highway, is it safe to drive until I get it fixed? Will the awning un roll driving down the road? Is there something temporarily can do to prevent the awning from unrolling?
The awning is a Dometic Sunchaser Awning and all the mechanical parts are OEM from when the TT was new, I only replaced the fabric
Thanks in advance,
Chris
  • It sounds like the spring is broken to me. I was told by a repairman that the right side spring is the one that always breaks, not sure why.
    Springs are only around $100 each, and you would spend that much or more in labor to find out if it's broken or not.
  • The spring could have come apart but sounds more like the locking meck broke and something is binding the end up
  • Looking at the trailer its the right side where the lever for rolling in/out is located ..... Im assuming the spring but I could be wrong because my experience with awnings is very limmited.... maybe something else?
  • Yes, I replaced the fabric about 3 years ago, every thing has been fine. A few times last year I seem to remember it starting to get a little tight un rolling
  • Have you had it out since you replaced the fabric? It sounds like you wound a spring the wrong direction
