JRscooby
Aug 24, 2022Explorer II
klutchdust wrote:
Replacing the bearing, replace the race. Pull a wheel, replace the seal. Always use a torque wrench on the lug nuts.
The first thing you should clean/inspect is the race and hub. Most likely you will save the hub so no waste in cleaning it. The race is easy to inspect, compared to bearing. And if the race is bad, no reason to waste time cleaning the bearing, they are junk.
