Baja_Man's avatar
Baja_Man
Axle Bearing Service - Dos and Dont's???
Trailer: 2011 Keystone 25RS
GVWR: 7500#
Axles, bearings, brakes, etc. have never been serviced. (the way I purchased from original owner)
Mileage: Approx. 10,000
Considering servicing my own bearings, seals, and potentially brakes. I'm pretty handy and have plenty of tools. I have never serviced travel trailer bearings before. Boat trailer bearings, seals, races, hubs, YES......but not travel trailer axles, bearings, seals, brakes, magnets.
A few questions I have been pondering:
Are there any good step by step procedures or videos you can refer me to?
Are brake drums turned?
When are brake shoes replaced?
Are magnets replaced? How do you inspect and what to look for in terms of wear, required thickness, etc?
Where can I source Timken bearings and quality USA seals?
Many thanks!
  • Don't assume you "need" new bearings, although I will often just replace rather than clean them to re-pack, myself, it's cheap. Napa will have, or just order online. Consider SKF as equal to Timken. If ordering online, lots of "fake" good bearings. I got some (for a 4 wheeler that NO dealers apparently carry because well, who knows) in a name brand box and the box was actually a poor forgery of the real name brand. Sort of comical and they were like 1mm wider so snap ring wouldn't go back in.
    I'm sure there's 100 threads on here and 1000 YooToob videos, but the process is quite simple and should be pretty easy with even a nominal amount of mechanical aptitude.
    Couple key things.
    1. Don't fill the whole hub cavity with grease. Some will say pack the bearings and that's all the grease needed. I prefer to fill the hub at least 25%? full of grease in addition to packing the bearings.
    2. If you replace bearings you should replace the races. you can drive them in out and back in with hand tools and wood blocks generally.
    3. Magnets, I don't know the actual criteria. Have replaced some, but generally if brakes just aren't grabbing hard and they should be.
    4. Shoes and drums. If it aint broke or wore out, don't fix it. I wouldn't turn the drums unless you feel they're warped or you have a brake shoe that grooved the drum. If the drums are off, I'll scuff them real well with (wire wheel, emory cloth, sandpaper). Restoring friction and getting rid of any glaze helps. And is necessary if you replace brake shoes.
    Finally, if you need more new components than not, buying complete new hub/brake assemblies "can" be more economical and quicker than replacing individual components.
