JCR-1ExplorerNov 12, 2016Axle CamberI lost my camber on my 21 foot Coachman Clipper. Wearing tires on the inside pretty radical too. Don't know how but apparently I went over a speed bump or hole and bent the axle to negative camber. Bu...Show More
rbpruExplorer IINov 12, 2016Are you sure you lost the camber, or did the axle slip in the clamps and rotate from positive to negative?. It is difficult to believe an axle can go from positive to negative but understandable that it might rotate in the mounts.Mine are rated below the max TT weight because some of the weight is carried by the tongue.
Related ContentWheel Camber?E350/E450 Ford Installed Caster/Camber Sleeves ?Bent axle.Dual axle vs triple axleAxle Service
