JCR-1
Nov 12, 2016Explorer
Axle Camber
I lost my camber on my 21 foot Coachman Clipper. Wearing tires on the inside pretty radical too. Don't know how but apparently I went over a speed bump or hole and bent the axle to negative camber. Bu...
Lynnmor wrote:rbpru wrote:
Are you sure you lost the camber, or did the axle slip in the clamps and rotate from positive to negative?.
It is difficult to believe an axle can go from positive to negative but understandable that it might rotate in the mounts.
Mine are rated below the max TT weight because some of the weight is carried by the tongue.
They can't rotate unless all the welds break on the spring pads. The 3500lb axles are a joke, the tubes are paper thin and the spindles have a design error.
