I lost my camber on my 21 foot Coachman Clipper. Wearing tires on the inside pretty radical too. Don't know how but apparently I went over a speed bump or hole and bent the axle to negative camber. Bu...
I think the best bet would be to replace as I think a recamber is not the solution. Its just not sized correctly if it bent the first time., and a recamber is a weaker component. I think something up around 4500 should work out better. Ill contact dexter and see if they can cross over my 3500 to a 4500 part number or see what options are out there. Torsion axles sound good as well but not sure about mounts to the frame .Good possiblity and worth looking into. Thanks
