vlopddap
May 29, 2014Explorer
69 Avion wrote:
As the height of the trailer goes up, so does the vertical center of gravity. Will it perform as well in a fast, tight turns? No, but if you aren't taking tight turns at high speeds you should be fine. Keep the heavy items that you pack in your trailer, on the floor and forward so that you have plenty of tongue weight and you should be fine.
Improper loading with insufficient tongue weight will create much more of an issue than your increased height.
Okay, I understand what you mean. Basically the "dry" tongue weight of my TT is around 15%, but add propane tank and battery that sit right on the tongue and you are WAY over 10%. So except if I put some VERY HEAVY things inside behind the rear axle, improper tongue weight distribution can't be an issue.
Anyway other fact about the 16BH is the cargo capacity is only 450 pounds according to the manufacturer label... so I guess most of our luggage will go inside the van except for clothes and food maybe. We never carry water by chance, but I think only the potable water reservoir weight over 200 pounds full of water!
44,056 PostsLatest Activity: May 04, 2014
