valhalla360 wrote:
kellem wrote:
The axle is likely a Dexter and will be labeled with the info.
Yes it's very common in the RV world to have the trailers GVWR to exceed the axles rating, surprisingly.
My last 2 trailers had (2) 3500lb axles yet both trailers exceeded 7000lbs in GVWR and in scale weight without issues.
Where does the GVWR sit with the hitch weight added in?
On an 8000lb GVWR trailer, you are likely looking at a 1000lb hitch weight, so add in a pair of 3500lb axles and you should be fine.
But in this case, the OP just mixed up the dry weight with the axle rating.
You are correct and good point.
Never would there be a case where the entire gross weight of trailer be sitting directly over the axles when tounge weight is absorbed.
