donn0128 wrote:
Actually David your wrong unless by Vancouver your in Canada. BC is the only state/province that I have heard aboit that enforces mfg GVWR numbers. No body actually cares until you are envolved in an injury accident.
I work for a Canadian construction company (1000s of vehicles and trailers) as well as Canadian friends with trucks and trailers, and yes the canukians do enforce gvws more strictly than the US. That said David is mistaken about tires and wheels. Already has a dually so stock tire and wheel ratings are well within spec with let's say a 3ton payload.
Plus we know AAM rates that axle around 10klbs. Good there too. Springs can be upgraded easily.
That leaves frame and spring mounts as potential weak links.
If one wants to go "pseudo" by the numbers, since none of us can realistically calculate the actual design strength of frame and spring perches.
Lose the "gvw" and class load limit ratings and look at the vehicles.
Take the same design truck, likely newer model with same chassis (frame and hard parts), base model, gasser single cab etc. look at the payload (which is likely north of 6klb for a dually). Now compare the curb weights to a 4x4 high optioned crew cab diesel. Say you have 1000-1500lb different. Now look at how much of that extra weight is carried by the front axle. 4wd, about 75% is front axle, diesel, all front axle, extra cab, over 50% front axle.
What you'll find is that the rear axle is carrying a small percentage of the additional weight. Subtract that 500lbs or so from the Max payload of the stripper/gasser truck and that is reasonably what the rear frame etc is designed to carry.
