Quote "Took it to the dealer, they did a laser alignment and stated rear axle is 1/4" out of line, said I needed new tires because they were not the right ones, they should have not been filled with nitrogen and that I needed an alignment and lift kit installed. Everything is from the factory, I have not done any thing to it. Does this sound normal or a factory problem. I can have all the work done and "it may" correct the problem for just under $1300.00. I feel like I'm being taken...Any thoughts"
You need to find a competent and honest dealer to start with and start over.
