thomasmnile
Sep 24, 2013Explorer
beachlovingmom wrote:
We will be taking our first trip longer than a weekend next month. We have Direct TV satellite at home. Can someone explain in simple terms what we need to do take it with us? Can I get an extra satellite dish from something like Craig's list or ebay? What parameters do I need to know? Can I take the bedroom box with us in the camper?
Things we need to be aware of?
Our trailer is a 2005. I am assuming the antenna on top will in no way help our digital TV. Is this correct?
Thanks much!
I have home service with Dish. To make your home receiver work on the road, the antenna you buy for the TT must be compatible with your home receiver, otherwise you may not receive all the channels the receiver is capable of tuning in. Also know you will not get local network affiliate channels like you would at home, I believe the receiver "smart" card is programmed to receive the affiliates specific to your home area.You will be able to view all the cable networks without problems. Our travel setup consisted of the home receiver a tripod mounted antenna, and 100' of coax cable. If you're camping in an area with a lot of trees the antenna has to have a clear "view" of the southern horizon to pick up the signal, hence the long antenna cable. Used all this only twice; was such a PITA to set up we stopped using it. Content now to watch DVD's or crank up the roof antenna and watch whatever the TV may pick up, if we turn on the TV at all.
44,065 PostsLatest Activity: Apr 13, 2026
