rfuerst911sc
Jun 26, 2014Explorer
back up camera questions
I'm doing a restoration of a vintage truck camper. I'm at the point of replacing the rear running lights with LED's. I want to add a back up camera. I believe I have two options. One is add a back up camera to the camper and power it by the center running light. Obviously this would be a dedicated camera as it would be hard mounted to the camper. Good viewing angle being installed up high. Second option is to use a license plate back up camera. This has merit because I can use on the truck or the camper. I would have a power pigtail on the truck and the camper with a slip connector. So two license plates screws and a slip in power and done. Viewing angle obviously is much lower but the convenience of being able to use on both vehicles is a plus. In either case I'm going to use wireless. So what do you guys/gals think ? If I go with the camper mount I need to run the pigtail when I replace the lights. I'm probably a year plus away from having the rig complete but I'll be replacing the lights in the next two weeks. Any advice is appreciated.
