I have a Pyle monitor with 2 camera inputs. I have a camera on the lift gate and one in the back window of the TT. Mine are on ALL the time to help with passing and clearance issues. It's nice to be able to check on the hitch and the back of the TT with the touch of a button. Installation was pretty easy. Bought the cams & monitor on eBay. Used RG6 tv cable and F to RCA adapters. Tapped power for the cams from running lights (I keep mine on all the time by covering the light sensor with a black condiment cup from Taco Hell). Wired the monitor to a switched spot I the fuse box. Use a quick disconnect sliding F connector and a F barrel connector at the hitch. I can post some pics if needed.
